I have a Carerra crossfire 3 2023.
Tires are 700 x 42c.
At the front, there's no thing on the wheel skewer nut qr thing for mounting stays.
I think they're called eyelets at the bottom of the fork.
There's rubber grommets on the suspension forks, behind which are screw threads, that requires an adapter to fit mudguards.
There's about 46mm clearance in width under that thing that is part of the suspension fork above the front tire.
Google search shows for a 42c tire, a 58-60mm mudguard is needed.
What mudguards will work with my bike?
I want ideally Matt black, not gloss.
Maximum coverage with rear flap if possible.
Thanks
Thanks
