What is the point of bib shorts?
gavintc
Southsea
keep your bollox in place. stops having a little tight line on your tum.
This question has been asked before just check the links at the bottom of the page, one of them asked by me. I was a bit skeptical before I tried them but the biggest advantage I've seen is that the pad stays in the right place when you stand up and sit down.
SoulOnIce
SoulOnIce
OK - ta. I like the funky "similar threads" thing at the bottom. Never seen that on any other forum I've used.
leedslad
er...Leeds
I actually find when riding into a cold wind, my bib shorts are worth their weight in gold. and yes , they make you look thinner :angry:
trio25
Comfort for me, I wasn't sure and there are hardly any females bibs out there but once I tried them I haven't looked back.
jimboalee
Solihull
I wear shorts. If the correct size is worn, there is no problem.
I have worn Bibshorts, and as far as I can see, they are sold to increase the manufacturer's profit.:biggrin:
I ditched bibshorts due to needing the lavvy (hidden hedgerow) during a 200km Audax on top of the Peak District. Far too much fiddling with removing jersey to get the bib down.:biggrin:
Ordinary shorts for me now. :smile:
theboytaylor
Charlton, London
I got some bibshorts recently and I've found them to be brilliant in this colder weather (although I have had a similar problem to Jimbo, not easy to extricate yourself quickly!). The extra coverage of my lower back was noticeable - before, no matter how high up I pulled my shorts, a gap would gradually appear between my top and my shorts letting the cold air in.
Bibshorts probably not necessary on warmer days, tho
jimboalee
Solihull
I've had a flash of inspiration and a patent application on the drawing board.
1 pair Cycle shorts, 1 lycra vest top & 1 lightweight zip fastener :wacko::biggrin:
Hey presto, bib shorts that unzip round the middle :smile:
