what do you use to map your ride?
hi, I have a windows phone. Strava seems to be iphone or android comparable. Anyone know what app I could use from a windows Nokia lumia phone?
Peteaud
South Somerset
jnrmczip
glasgow
Endamondo is what I'm using as strava was annoying my by closing a lot and missing out some sections of my ride. I am using Android and endamondo is working excellent so far
Bryony
Ramsgate, Kent
My OH has a windows phone he used to use map my ride but it wasn't all that reliable. We both have garmins now, saves the phone battery!
Eribiste
Careful with that axle Eugene
I recently bought a Garmin Edge 200, which works very well. I upload the results to Garmin Connect which is linked to Strava and those services give all the detail and analysis I want.
fit447
Regular
Derbyshire
Without an i phone, I rely on MOPEMETER website, to log my routes before I set out. I can check the total ascent, check out where the big hills are, and check for reasonable detours if I want to extend or cut short my ride. I can log my routes, and keep a record of my weekly/monthly distance. works well for running and walking too.
Its a good alternative for anyone who isn't too keep on too much technical stuff, like me!
bowtomephil
Used Endomondo for a year and it was excellent, it does real time tracking and works well. Problem with all phones is if you do a lot of miles. I now use a garmin 800 which is fantastic.
Deleted member 23692
I've got this and it's very good.
it'll give voice turn by turn directions, give you verbal stats whilst on route, sort out a route to your chosen destination, upload to either Strava or Ride with GPS, and follow routes that you've loaded on via Strava /Ride with GPS. Plus sheds loads more
The only problem is it uses up the battery, and I'd rather save that battery life for the time I just might need to make a call
Agreeing with Ffoeg that it is better to save phone battery power for the phone. I use a nice little geo-tracker called the Holux 345. I have had it for years and have used it for skiing as well as walking and cycling. Pretty accurate and goes for days on its own battery. You can see a map of my ride from yesterday on the Bianchi thread in General Cycling Discussions.
si_c
Wirral
Another +1 for runtastic, I've got the pro version and it's ace, I find the interface better than that of strava, more customisable especially for the active session.
Once I've uploaded stuff using the app, I then download the GPX files and upload to strava.
John the Monkey
Frivolous Cyclist
Crewe
Mrs M has Runtastic on her Windows Phone (Lumia 620). Sports Tracker isn't bad too - I've used it from its Symbian incarnation.
Just be aware that not all have Strava's privacy zones, so be careful who can see the start and end points of your rides.
