What do people mean
jowwy
Can't spell, Can't Punctuate....Sue Me
When they say that a bike has a
a) Relaxed
b) Aggresive
geometry - confused.com
A bike with a relaxed geometry usually has a longer head tube and allows the rider to sit up more relaxed whereas an aggressive frame has tighter geometry allowing the rider to get into a more aggressive, aerodynamic position.
Moodyman
In lay man's terms...
Relaxed = more sit up = more comfortable = slower
Aggressive = more arse up = less comfortable = faster
the snail
Chippenham
It's also about stability, a tourer will have longer wheelbase and slower steering, so it will be more stable and more comfortable over bumps, as opposed to a racebike where quick steering is more important.
GrumpyGregry
Here for rides.
I'm with the snail. Relaxed geometry means a stable, slower steering, aggresive means twitchy faster steering.
aberal
Midlothian
It relates to the frame geometry - typically a racing frame will have a shorter wheelbase and fork rake with traditionally a seat tube angle of 74 degrees. A tourer will have a longer wheelbase and fork rake and traditionally a seat tube angle of 73 degrees. Nowadays with compact frames with sloping top tubes these angles don't always apply, but the same principles remain. Steep seat tube angle = aggressive, shallow seat tube angle = relaxed.
J
jowwy
so would adding a stem riser help my bike become more relaxed????
aberal
Midlothian
No. It would help you become more upright on your bike.
GrumpyGregry
Here for rides.
Changing the stem length can make quite a difference to the steering, as does swapping the forks to ones with different crown to axle length.
(well it does on an mtb so no reason why it wouldn't apply to a road bike.)
