What do I need to change a Bottom bracket on a new(ish) Brompton?
Kell
I've not looked at this properly yet, but got a clunking noise on my Brompton last night. When I picked it up to have a look, the whole crankset is moving.
It may be that it just needs tightening, but essentially, I'll need the same tools for that as for removal. The question is, is the current Brompton with a Spider chainring just a simple matter of crank pullers and a Shimano BB tool? Or do I need something special?
Thanks in advance.
Kell
Kell
Also - if I do decide to replace it, what are people doing in terms of upgrading?
Fab Foodie
Kirton, Devon.
I've not looked at this properly yet, but got a clunking noise on my Brompton last night. When I picked it up to have a look th ewhole crankset is moving.
Thanks in advance.
Crank pullers and Shimano square taper BB removal tool.
I upgraded to a 50/34 Stronglight double on the same BB. Gives me 2 gear ranges. Even with the 34 you get a useful gear range over flat ground. £50 well spent for me,
Kell
Kell
Thanks for that.
Looks like there's a Shimano UN55 in 68x118. The details on a direct replacement says it's 68x119.
Would that cause me problems? Clearly the chain line is going to slightly further in, but is it enough to make a difference?
Tim Hall
Crawley
Thanks for that.
That's 0.5mm per side. I'd say you'll be fine.
Kell
Kell
It's just over a year old.
And done about 2,500 miles.
Might not actually need replacing, could just be that it's come a bit loose, but I figure an upgrade would be no bad thing.
GrumpyGregry
Here for rides.
If it is so loose the cranks are wobbling either your bb or your cranks, or possibly both, are now likely scrap.
Tim Hall
Crawley
New?
Warranty!
Wot Mickle says. Mind you, a few years ago we had what felt like a loose/worn bottom bracket on The Boy's bike, after one year use. Took it back to Evans, who said bottom brackets were consumable and it wasn't a warranty item. I <polite version> expressed incredulity but they wouldn't budge. Closer inspection at home revealed that the adjustable cup had come loose, easily remedied by application of BB tool, 32mm socket and suitable amounts of grunt.
shouldbeinbed
Rollin' along
Manchester way
Have you got the old style FAG BB with the castellated plastic lockring?
If so, you'll need the relevant spanner, Park Tools BB4 IIRC or a bodge to get it off. I didn't have one so nipped into LBS and borrowed theirs.
Kell
Kell
I thought it might need a specific tool as it does have crenellations on the outer rings, but it also has splines which look like they'd take a Shimano bb tool.
And yes, I'm aware it's minging.
12boy
Casper WY USA
I can't tell from the photos I pulled up if the UN55 has a plastic ring on the left. If it does I would recommend not tightening it to much, i.e. flush with the frame. I have had a number of those split from overtightening. All it really does is support the bracket on that side and tightening, or not, does not affect the cartridge bearings. If it is aluminum it won't split and you can tighten further. It is the right side that really matters. BTW, I grease the threads before installing, so as to prevent rust and sticking when later you replace it. I do not grease the square taper ends of the spindle. Remember that the right side ain't "lefty loosey, righty tighty" since the threads are reversed on the right. I replaced the original FAG bracket on mine with a Vuelta 119 mm, about 12 bucks, and it works fine thousands of miles later.
GrumpyGregry
Here for rides.
Not just Evans that say that :sad:
