What do I need for a "strip-down"?
mythste
Manchester
So I earnt my summer riding over the winter but I fear my bike is worse off for it. I'm getting creaks and clicks and pops of all manner coming from various places and I wouldnt be surprised if everything needs to be taken apart, cleand, re-greased/lubed and put back together again - shes seen 1000 miles since new now and its probably well passed due! (I do mickle my chain once a week though!)
My question is, What tools do I need to take her apart? I've all manner of allen keys and screwdrivers knocking about, but is it worth me popping the bottom bracket out and taking the rear cassette off etc for a deep clean? recommendations for a cheap chain break tool and a tutorial for getting it back on?!
Thanks in advance - the bike is a Focus Mares 3.0.
subaqua
What’s the point
Leytonstone
unless the BB is feeling rough, then not worth it taking it out. its easier to clean a cassette on the wheel than off ( unless proper claggy with gunk) i bought a decathlon chain tool it lives in pannier with a link taped to it.
only time BB comes out is for a new one or when it starts to feel rough. and you can feel that early anyway
Cubist
Still wavin'
Ovver 'thill
Any modern bike can be stripped with a surprisingly small number of tools. If you're going to do a full strip and service you'll need a workstand, as trying to fettle while it's upside down is soul destroying. You don't need to spend the earth on one, eBay has loads of budget stands, but get one with QR jaws if you can, they make life easier.
Good allen keys. You actually only really need 3,4,5, and 6 mm ones, and the six is only really for pedals and stem bung fixing, the three for bottle cage and rack bosses. Treat yourself to a decent set of long handled "P" type, but double up with short standard 4,5 and 6. There are some bolts which the long reach ones won't get to. The 4 and 5mm ones are the ones you'll use the most.
A decent pair of pliers, bull-nose and needle nose. Just because.
Cable cutters. Invaluable.
Chainwhip and lockring tool. A chainwhip is vital for swapping cassettes, but you won't use it very often. To keep costs down, get a 1/2" drive ratchet with a quick release button. You can get decent ones for less than a tenner on eBay, and you can attach all manner of more specialised tools to it, and the lockring tool is one of them.
Similarly, a Hollowtech BB tool is best in 1/2" drive version. While you're at it splurge a quid or so on a nylon Hollowtech preload cap tool.
A couple of decent cross-head screwdrivers. Get one that fits the limit and B tension screws on your mechs properly to save chewed heads.
A set of seal picks or dental picks(again, a couple of quid on eBay) and a grease gun... Halfords do one that takes their tubes of grease for not much money.
Have a supply of sundries knocking about... cable saver doughnuts, cable end crimps, outer cable ferrules in 4,5 and 6mm flavour, zip-ties and electrical tape.
A chain breaker is useful, both in your pack and in the workshop. Buy a forged one for home, cast ones break before the chain does. Save yourself the heartache of trying to peen joining pins, get a few quick links and some quick-link pliers. Faster, easier, more secure joins.
Lastly, a tube of coppaslip, a tub of general lithium grease, or marine grease if you ride in sloppy conditions, a can of GT85 (look after the little red straw!) and if you have any carbon components, a tube of carbon assembly paste. Finally, a bottle of 99% Isopropyl Alcohol off eBay is great for any emergency degreasing and cleansing required.
I'd recommend sourcing all of the tools from someone like Superstar Components or On ONe. Their tool range is perfectly adequate for enthusiastic amateurs, and they'll have Bank Holiday deals on at the moment. Wheelies Direct have a sale on tools as well.
mythste
mythste
Manchester
Wow, what a comprehensive reply. Seriously appreciated! :smile:
simon.r
Person
Nottingham
I reckon @Cubist is about right. I'd add a pair of outer cable cutters to his list.
Give your bike a good wash before you start taking it to bits (Muc Off works well) - it's easier and nicer to work on a bike that's reasonably clean.
Anything you're not sure about, take photos or notes before taking it to bits (e.g cable routing, saddle set back).
If you're stripping the bike down I'd take the BB out and coppaslip the threads. It should be relatively easy to remove now, but they can be very difficult to get out if you leave them too long, especially if it was assembled dry (which seems to be normal).
It's also worth replacing the cables while you're at it, or at least removing the inners and flushing a light oil through the outer.
