What could have caused this? Lots of bubbles from tube in a line.
  • Thread starter Deleted member 121159
  • Start date
My Ridenow TPU tube started leaking which got worse over time so finally took it out and had a look. I discovered a straight line of 10-12 small holes! And they don't seem to be facing the tread, rather the sidewall or even the rim. But I couldn't see anything suspect on the rim. Any ideas?
Deleted member 1258
Do you have rim tape fitted? if you have what condition is it in?
https://www.bicyclerollingresistance.com/specials/tpu-inner-tubes
Get's a reasonable rating and only 36g: wicked ;) though not if it leaks.
Maybe suffering slow degradation through hysterical friction at the rim tape edge / rim line.
The nature of leaking is different from latex tubes. TPUs don't normally leak, but this one obviously developed strange holes on the side. Could be friction against a slightly rough surface over time that caused them, who knows. I've decided to go tubeless for the rear wheel anyway.
