What brakes for my bike?
J-Dog
London
I've never done any bike work before but need to put some front brakes on an MTB that has been made fixed wheel.
What type of brakes should I put on it and if I have options, which will be the easiest to fit?
Thanks.
tyred
Ireland
Are you using standard 26" MTB wheels? If so, your frame should already have braze ons for cnatilevers so they should fit straight forward.
betty swollocks
large member
Questions: need some more info about the bike:-
Do you have straight handlebars or drops?
What wheels/frame do you have - suitable for rim brakes or disc brakes, or both? What is your preference?
RedBike
Beside the road
It all depends on which wheels, forks, bars and levers you want to use. You're probably looking at v-brakes for flat bars and canti's for drop bars.
J
J-Dog
London
Its one of these bad bwoys but with straight bars:
RedBike
Beside the road
That isn't a MTB!!
I can't see very well from the picture but they look like deep drop duel pivots.
Duel pivot brakes wont work correctly with standard v-brake/mtb levers. You need to make sure you get flat bar road bike brake levers.
J
J-Dog
London
This is what is on there now.
A new set of cables and a clean up would improve things a lot, and be much cheaper than new calipers. If it's still not good enough, buy a set of dual pivot caliper brakes. Best to go to a good bike shop to get them, because not all of them would fit.
J
J-Dog
London
Thanks. Will go the cable route.
Its such a shed and I'm a beginner but I'm also skint so want to do it myself.
