what bike to get???need advice
newbikerider
im am looking for a bike to comute to work and long bike rides on the weekends,i have found a few to chose from.
im on a bit of a tight budget and have up to £250 to spend on a bike,heres what i have found on ebay,can someone recomend somthing decent for my budget.
thanks and regards
stevo
2011 viking giri d'italia road racing bike new 14 speed
BARRACUDA RS200 MENS ALUMINIUM ROAD RACING BIKE
2010 COYOTE BIG SUR ROAD RACING BIKE RACER
Kestevan
Last of the Summer Winos
Holmfirth.
The Viking seems to be well received by the ones on here who ride one (angelfishsolo i think).
My daughter has a coyote (not this model) and for a low end bike it's reasonably well built and definately a step up from the usual BSO fare.
If you can up your budget slightly you may also want to consider what I think is the best new bike available at this price bar non, the Triban 3 from Decathlon - it is £299.00 though.
http://www.decathlon.co.uk/triban-3-id_8167038.html
Oh, and remember if you're commuting you'll probably want to add some mudguards, maybe a rack, perhaps some clothing, a helmet and at the very least a decent lock..... this can quickly add to the budget.
jay clock
Massive member
Hampshire UK
I looked at those three and sadly I would not recommend. The parts look to be very old design. Can't remember which but one has a solid rear axle, screw on freewheel, another has some sort of the shifter mounted on the bars. I suspect quality will be very low all round.
Agree, decathlon is the place to look - superb bikes for the money.
jowwy
Can't spell, Can't Punctuate....Sue Me
is it a drop bar you want specifically - cause rutland have a great sale on with the felt qx65 hybrid flat bar racer
its a steel at £240 notes.......
Angelfishsolo
A Velocipedian
thanks and regards
stevo
The Viking has been a great bike thus far. Yes it has trigger shifters on the flats and a solid rear axle but apart from one stiff chain link it has not missed a beat. For the money it is a lovely machine.
Angelfishsolo
A Velocipedian
From my experience of the Viking you suspicions are incorrect. Yes it uses some old fashioned technology but big deal. I have done some pretty serious riding on it and as said previously apart from one stiff chain link it has not missed a beat.
cyberknight
+1 grab a bargain, mines done me proud as a commuter/ entry level weekender.
http://www.halfords.com/webapp/wcs/..._productId_272635_langId_-1_categoryId_165710
jowwy
Check this bike out it has to be a serious contender
Enlarge this image
Felt QX65 2011 - Hybrid Bike
RRP £374.99Only £239.99Save £135.00
(€ 292.03)
Delivered in 1/2 working days while stocks last!
http:// 52cm - £239.99 55cm - £239.99 58cm - £239.99
More Gent's Hybrid Bikes
More Felt products
More Felt Gent's Hybrid BikesThe Felt QX65 2011 Hybrid Bike is a highly comfortable, versatile and simple to ride bike that is highly efficient like a city bike, but incredibly durable like a mountain bike.
The Felt QX65 2011 Hybrid Bike is perfect for commuting or for off road fun, with a lightweight butted aluminium frame and 21 speed Shimano shifting.
Specifications:
  • Frame: Felt Cross Design, 6061 Butted Aluminum. Semi sloping Hydroform TT, A Style Seatstays and Chainstays. V' and Disc-Brake Compatible, Integrated Kickstand Mount, Basta Lock Compatible
  • Fork: Felt HiTen Unicrown Fork 1 1/8th High Tensile steerer tube and legs, V-brake bosses and Fender eyelets. Suspension modified length
  • Front Derailleur: Shimano FD-M191
  • Rear Derailleur: Shimano RD-M360
  • Shifters: Shimano ST-EF51 Non-Series, EZ-Fire Plus Brake/Shift Levers, 7-Speed
  • Chainset: SR-Suntour XCT-T208 Melt-Forged Aluminum
  • Chainrings: 48/38/28T Steel Rings
  • Bottom Bracket: Sealed Cartridge
  • Cassette: Shimano MF-TZ21 14-28T Freewheel
  • Chain: Shimano UG51 7/8 Speed
  • Pedals: MTB Design, Toe Clip Compatible
  • Front Brake: Tektro 855-AL, V-Type Brake
  • Rear Brake: Tektro 855-AL, V-Type Brake
  • Brake Levers: 2.5 Finger Included with Shifter
  • Handlebars: Felt MTB Design Riser bar
  • Stem: Felt MTB One Piece 3D-Forged Design
  • Headset: Semi-Integrated 1-1/8"
  • Grips: Felt Ergo Grip Dual-Density Kraton Rubber with Ergonomic design
  • Rims: Alloy Double wall Black Anodized 36 hole
  • Front Hub: Forged Aluminium, with Alloy Quick-Release Lever 36 Hole
  • Rear Hub: Forged Alloy, Spin-On Type (7-Speed), with Alloy Quick-Release Lever 36 Hole
  • Front Tyre: Felt X:City 700 x 37c
  • Rear Tyre: Felt X:City 700 x 37c
  • Saddle: Felt Mountain Design, Low Side Profile Look with Comfort Fit Top
  • Seatpost: Felt Alloy Micro-Adjust, 6061 Alloy
  • Seat Binder: Felt Bolt-Type, Cold Forged + CNC, 6061 Aluminium
The Felt QX65 2011 Hybrid Bike is part of a wide range of Felt Hybrid Bikes available to buy from our online bike shop.
thank you will have to save some cash now!!!
Why? If I had your budget I wouldn't even be looking at new bikes TBH. You'll get a great bike with decent spec components for your budget if you look around.
Check out place like ebay, and if you see something you fancy just post a link on here, people will gladly tell you what they think and give you their honest opinion. Even check with your LBS, they may have second hand bikes you could pick up too.
