What are these for??
karlosondet
Member
Hi all and this is my first thread so please bare with me!!
I have just put a bike together and I am left with 2 bits that look like a can ring pull (attached)...... Any ideas please
Overconfidentii Vulgaris
^^^ What @User said. They are to help prevent the wheel dropping out if the wheel nuts (or quick release) are loose.
My knockabout bike has them, but better quality bikes usually have a lip on the fork in place of these.
KneesUp
They are there so you don't sue the bike maker if you are too incompetent to use a quick release properly.
Forks didn't used to have these, or annoying 'lawyers lips' - in fact mine doesn't, because it's ancient. Get rid of them - they just make taking your wheel off a faff. If you use the QR properly there is absolutely no need for them. Unfortunately a few lawsuits from those unable to do so led to this sort of sillyness for all of us (except people with old bikes) :smile:
karlosondet
karlosondet
Member
Cheers for that and pretty competent with Quick Release been mountain biking with Quick Release for a while, just thought I would try road biking for a change!!
If not essential I will lose them for sure!!
Cheers for the info
young Ed
pretty sure my second hand mid range road bike (modern) doesn't have them but i will check. but then again before me last owner did change wheels twice and if they were here to start with they probably would have been lost or thrown by now
Cheers Ed
karlosondet
karlosondet
Member
Cheers for all the help everyone have them now fitted see how long it is before I lose them!!
KneesUp
There was also this even more annoying type that bolted into the mudguard eyelets, so you needed an allen key to get your quick release wheel off. I seem to remember this type being marketed as some sort of anti-theft device though. (Excuse bobbins 'mobile phone in low-light' picture)
young Ed
if you do indeed need an allen key seems to defeat the point of having a quick release!
Cheers Ed
KneesUp
Cheers Ed
You could also so it by un-dong the nut off the skewer and pulling it out, but if you had an allen key that way was quicker. I have two in my box of bits. I doubt I'll ever use them :smile:
EDIT - unless you had two on the same wheel, in which case you really did need the allen key
