What are the best cantilever brakes
Anyone out there give me some recommendations for the best performing cantilever brakes to replace my rather old and tired ones on my touring bike please
Never used them but the avid shorty are supposed to be good brakes.
John the Monkey
Frivolous Cyclist
Crewe
What levers do you have?
For Tiagra STi, I like Oryx, but they have to be gapped *very* close to the rim to work well, and need relatively frequent adjustment.
Tektro CR720 will give you more clearance, at the expense of (ime) power.
For levers designed for cantis, I don't really know, as I understand that they are better tuned to the mechanical advantage of a conventional canti brake. Anecdotally, for such levers, the CR720 with a reasonably low straddle wire is thought to be good.
John the Monkey
Frivolous Cyclist
Crewe
With STI's?
Possible - either with travel agents (which personally, I don't fancy very much) or with "mini-vs" which have shorter arms to match the mechanical advantage of road levers. I've yet to try them myself, but intend to at some point.
This is a useful thread for figuring out what sort of mini-v you need;
http://forums.roadbikereview.com/showthread.php?t=146309
The plus of these is that they tend to be cheap (£10 - £15) so it won't break the bank to try them out.
http://forums.roadbi...ad.php?t=146309
That's interesting JohnTM; my v's are 90mm and I use them with travel agents and the braking is not perfect but it looks like I can get 75mm. The bike's on the turbo atm but if I ever put it back on the road I might try 75mm brake arms ;-)
John the Monkey
Frivolous Cyclist
Crewe
I did the measuring and the LHT needs 85m, by my reckoning. It's something I keep meaning to try, but it's at the back of the queue behind a couple of wheel builds &c :smile:
