fraz101
View: https://youtube.com/shorts/bCSDtySOxSY?feature=share
Began today after 30 miles. Happens pedalling or not.
If I remove the wheel and spin it on its axle it doesn’t do it.
I’ve tightened spokes. Not any better???
I’ve ensured it’s not that.I notice you've got a sensor of some sort on the chain stay. Presumably there's a magnet on one of the spokes, which is maybe a little to close and making contact?
Worked through the following on this.A few idea for you here
https://jimlangley.net/wrench/keepitquiet.html
I will check all the above tomorrow, the click happens without the chain turning though, it is a new chain but has been on a few months I believe.Given the spokes are under reasonable tension, the nipples will NOT be "moving inside the rim".
The clicks I can hear are not at wheel rotation frequency.
If you remove the disc pads and refit the wheel. Is the click still there?
Remove the chain and spin the wheel> Click?
Have you cleaned and inspected the chain?
With the chain set up as normal, looking from the side in a middle of cassette sprocket, does the RD cage move forwards/back as the crank is turned?
Couldn’t resist, just removed pads and retried, still there. I’m convinced it’s from the spokes.I will check all the above tomorrow
Thanks
Could be wrong but I don’t think they were fitted with these from factory.Sounds like a piece of plaster not metal. I'm going to guess someone removed the dork disk by cutting it out (rather than removing it with the cassette) and left a bit of plastic behind the cassette.
Thanks. Not sure what else it could be or to try….So looks like not the brakes. Do not fixate on the spokes; please! It's irrational: if it was a spoke the click (whatever) frequency would be directly related to the wheel rpm.
