w00hoo_kent
One of the 64K
- Maidstone or Greenwich
I have a Synapse with a creaky crank and a set of sparkly new wheels. CRC finally delivered the new Durano + to replace the one I lunched last Saturday and with an intention to retry the 110 mile route on Saturday I figured, swap the wheels, grease the bearings, and all good.
Cue noob failure.
So, when I asked the LBS for a tool to remove the cassette from the rear wheel they happily sold me one, they neglected to mention it was useless without a chain whip to hold the cassette in place to undo the lock ring. So I line it all up and find out it just spins. Humpf. OK, I have the original wheels now with a full set of spokes and trued up, all I need to do is grease up the bearings to stop the creaking and swap the Continental the LBS put on to replace the faulty Lugano out for the new Durano +. I get my trusty 10mm hex key out, can I remove the crank, can I bollocks. I add some leverage, still not interested in budging. On to the internet and the video of a guy replacing the BB30 on a Synapse shows him heaving away with a torque wrench to make the crank bolt turn. At the end of things he mentions torqueing the crank bolt back up to 40nm. Yeah, not only am I not going to get near that with a hex key to take the crank off, I'm not going to be able to match it tightening up again.
So I have a chain whip on order, I have a set of 1/4" drive hex bits on order, they'll be here sometime next week. Saturday is cancelled. I am officially a bit grumpy.
I could just swap the tyre out and do the ride, but the crank started creaking after it got wet and it's really bugging me, I'm not sure I can last 7-8 hours of it without becoming homicidal.
Cue noob failure.
