Welding aluminium frames ?
RufusChucklebutty
I'm thinking of a project to change the dropouts on a MTB frame to horizontal to build a hub gear touring bike, I already have the nexus hub gear wheels and a couple of frames, a MTB and a Hybrid, so I could build this bike for peanuts compared to buying new, I can get the TIG welding done by a friend of mine that's a coded welder and welding instructor but he's never done bikes before.
Can anyone give me any info on the welding , what alloy should the dropouts be made from, what kind of weld fit up , does it need re heat treating, what kind of jig is needed to set the parts up true ect ect.
Mfezela
Rather choose a welder who already has that knowledge and that experience. You and your welder chum are at real risk of spoiling a friendship. Every reply here will probably give you a different opinion.
Once a Wheeler
…always a wheeler
Welding aluminium is a specialist job. I have done some amateur brazing and fiddled about with aluminium to see how it behaves, with the result that I would never try to weld aluminium myself. It is far too easy to liquify the whole job — seek a specialist.
R
RufusChucklebutty
Where can I buy a no frills aluminium touring frame with hub gear dropouts ?
My level of riding I've never noticed any difference between a £200 bike's frame to a £800 bike's frame, no frame has ever broken or worn out on me.
Drago
As above, you'll destroy the heat treatment that gives most halfway decent alloy frames their strength and resilience. I'd use a pro, otherwise wouldn't bother.
rogerzilla
Horizontal dropouts get a lot of abuse as the wheel is slid into varying positions for chain tension. Aluminium isn't the best material for a bike with them, unless they have steel inserts or replaceable facings (like a Dolan Pre Cursa track bike).
