I'm hoping someone can help me with a "weird" gear issue. I have a Shimano Tiagra system with a triple up front and 10 at the rear.
My gears are set up but I can't get them quite right (and neither could the guy at the LBS). Changing down is no problem, pretty smooth down to the smallest cog. Then when you try to change up 1 (to 9th at the lever). it doesn't. Changing to 8th at the lever switches to 9 at the cog, 7th level 8 cog and so on, to 3rd at lever 4th at cog. The next up shift changes to 2nd at lever 2nd at cog i.e. correct!
Tweaking the index adjuster doesn't work, it stops the change down. In short, I can't win.
I looked at the change down / change up at the smallest cog. On the change down the rear mech moves (as expected) and changes. Changing up at the lever it hardly moves at all, so no surprise it doesn't shift at the cog. I can push it with my fingers, then it moves to 9th cog and stays there. So I was thinking it could be the cable tension, but see comment about adjuster above - seems to rule that out.
I should say that I crashed the bike on ice back in Feb, and the whole rear part of the drivetrain had to be replaced. LBS had to straighten the dropout as well, but it seemed OK. The cables etc are all fairly new (<1000 miles).
Any thoughts? My best guess is some sort of damage to the lever, I've had this before on a MTB shifter where the nipple housing was damaged and the change up then pulled the nipple into the damaged housing. I don't fancy messing with STIs though.
Thanks, Paul.
Thanks, Paul.
