Billy213
Regular
As the title suggests, I'm looking to lose weight. There's plenty of it to be lost so I thought I'd come here for some advice/ recommendations/ support and so on.. I'll get straight into it otherwise I'll end up waffling on.
As of typing this:
6ft 2" or 187cm
21st 4lbs or 135kg
BMI of 38.2
I bought my first road bike yesterday, a discussion on which can be found here.
Today I went for my first ride, up nice and early. 5.6km which included a short steepish hill (twice, because I took a wrong turn). It felt good. For my first time on a bike in probably 10 years and my first time on a road bike and actually riding in the road I really enjoyed it. So much so I went out and did the same ride again (minus the wrong turn and the second hill) for another 4.8k.
I think I'm off to a good start. If I can keep this momentum up I know I'll be achieving longer distances in no time and with that the weight and fitness should both improve. I'm also pretty active at work. I'm an operators assistant in a small power station which pretty much means up and down the boiler house all day. Plant checks, opening closing valves and all sorts of other wonderful things.
I'm also cutting out smoking as of today, which always went hand in hand with drinking. I'm going to cut back massively on my alcohol intake and possible cut it out altogether. Smoking has only ever been a social thing for me so I'm sure that part will be fairly easy. Alcohol has definitely been the biggest contribution to my weight gain over the last four years.
With regards to a diet I think my first step will be portion control. I generally eat well. Usually a take-away once every 10 days (final night shift treat). I'm not saying everything I put in me is wonderful and healthy but there's a fairly good balance.
So that was my attempt at not waffling. All input on this would be greatly appreciated. I'm new to this forum but I've already seen how active it is and I'm certain you lot can help me on my way.
As of typing this:
6ft 2" or 187cm
21st 4lbs or 135kg
BMI of 38.2
On a serious note, is there anything I can do to boost my calorie intake whilst still keeping it healthy? My lunch tomorrow will consist of a ham and egg salad with a couple of cereal bars and fruit of some kind to see me through the rest of the day.
