We need to talk about it
Jameshow
You can replace chainrings on ht2 chainsets just the bolts are hidden iirc.
Moodyman
Hollow Tech bottom brackets are just crap. I had enough of changing them far too often. Far too easily damaged by water ingress. Back to square taper for me.
They are indeed inferior to square taper and I too was replacing them often. I then moved to packing them with weather resistant grease upon installation (Silkolene Pro as used by motorcycle workshops) and adding a grease lip between the outer plastic cover and inner seal. Mileage has improved hugely.
presta
I had a 2007 Octalink Hollowtech 1 chainset, it was great: still not worn out after 28,300 miles, easier than square taper to fit & remove, and the chainrings were replaceable (I fitted a new middle ring several times). The previous square taper BB lasted 16,300 miles.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Cheap and easy though.
Indeed, but pain in the arris to have to 1: keep forking out for new BB's and 2: having to change the bloody things.
I've changed over to Spa square tapered cranksets and BB's. Not only they are a great price, especially individual chainrings, they look good too.
