I noticed today whilst lifting my bike, a water swishing sound. I was surprised as the water bottle wasnt in the bottle holder.
As I swayed the bike, I could hear the water going up and down the cross tube.
My mistake was to let the water leak out of the headset, as this made the headset gritty. New replacement integrated headset is now on order, as the dirty water had ingressed into the sealed bearings. About half a pint of water was drained out!
When I took the headset apart I could see signs of corrosion, as the water had been condensing up there for some time. The bottom bracket appears to feel okay.
The bike is a ribble sportive. The only points of possible water entry I can think off is the seatpost clamp, or more likely the front derailleur gear cable which passes through the carbon frame near the rear wheel and exits somewhere under the bottom bracket. I think the exit hole for the gear cable on the underside must have gunked up and held the water. I have now cleared it, so will keep an eye out after any future wet rides.
I am still however concerned, as the exit hole on the underside is still about a centimetre from the lowest point, so could still hold some water.
Any tips on how to deal with this problem? Ideally there should be a drain hole at the bottom of the bottom bracket.
Have any other carbon frame owners experienced this?
