I had a look at the washer because it had an annoying little leak. Not much at all but it was there after every wash. I hoiked it out and turned it over and something clattered around as the machine went onto it's side.
This device is what was rattling around:
It's plastic, about 60mm long and has a hole through it.
I've found what was causing the leak. Nothing to do with this device.
So seeing as how the machine was working fine apart from the small leak.
Do I ?
A) Strip the rest of the machine apart to see where this came from ?
B) Ignore it and just bung the machine back and hope for the best ?
C) Dither about and leave the machine open and all over the place until I find out what it is ? (Mrs Colly isn't keen on this option)
The machine is a Hoover VDH Sensor Spin. Any washing machine engineers on here ??
Do I ?
