My wafty town bike has a front dynamo hub with M9x1 axle threads, the rear being a IGH with 3/8"x26tpi axles.
I was a bit shocked to find that there are no washers separating the nuts from the ally frame and fork; resulting in paint loss and mess, especially at the plain nut under the bell-crank / shifter unit on the rear hub.
I'd like to add some washers but am having issues finding any; neither M9 nor hub-specific washers seem to be a thing. If it comes to it I can always drill out some M8 items to fit (and tbh these would probably have a more appropriate OD anyway).
Is it typical that hub nuts aren't fitted with any form of washer? Can anyone think of any issues that fitting them might cause? I'm aware that if spacing the gear shifter out further along the axle I'll have to adjust it to keep the indexing correc but I'm hoping that I should have enough adjustment to accomodate a thin washers..
Any thoughts much appreciated, ta
