kloeshuman
- U.S.A.
Not sure if anyone will know for sure, but I had started to do a SS build on a old frame I had. The BB cup broke when I was taking off the old crank set, I used that crank on my road build. So the other day I went back to removing the old bb. I ended up having to put a small amount of heat to it in order to break it free. Now, I can not get a bb to go back in straight, I tried the old one which was fine other then needing a new cup, I tried a new one also, still the same. It will not go in straight, not off by much, but enough that the other cup will not go on without binding on the spindle. Do you think that what heat I did use messed up that area around the bb? I should have said it is a aluminum frame. Should I scrap the frame and start another project? Not really a ss frame but I bike I put a lot of miles on so I was kinda hoping to keep her going.
