Looks like a plastic mudguard. If it is, mark the area that fouls the front mech (masking tape or similar) heat with an electric heatgun and dimple the area with something like the end of a handbrush. Don't overdo the heat.
Or use some snips to chop out a little bit of the mudguard where it is fouling. I've just bought mudguards where the dimple suggested above was already in place. I've still had to do a bit of surgery round the rear brake.
Maybe move the whole mudguard up a bit? ie drill a hole lower than the one with the spacer. That could possibly move it further away from the mech without risking fouling the tyre.
I'm thinking you need the whole mudguard back.
Putting a spacer in just the bottom won't do that, it will just move the bottom in a bit.
You also need the mudguard bridge back as well.
How have you attached it to the seatstay bridge ??
