mythste
- Manchester
nope. Try as I might they simply don't fit.
If you're a comfortable cycling 32 these will be fine. I'm a "jeans probably a bit lower than they should be" 32 and I'm not.
Probably been worn 10 times, always over bibs. And look in perfect nick apart from a little wear to the inside printed label - they're shorts designed for cycling. That's where you sit!
Typical vulpine high quality, I've just ordered some slightly larger ones.
£40 posted. Bank transfer/paym or pickup from Liverpool. I'm afraid I've fallen out with PayPal so that's not an option at the moment. Link to eBay feedback available if required!
