Voodoo Bizango 2016, correct front mech?
Cycleops
Accra, Ghana
I'm assuming it's a band on type and not a braze on fitting and bottom pull?
The one you have linked is s high band spec which means it fixes higher up the seat tube than normal to clear any bottle mount fittings if they are low and would interfere with a regular fitting.
The only thing to do is look at Shimano's technical sheet and see if the dimensions would suit your dear tube. If you have no bottle mounts to worry about you should be fine.
