Voodoo Bizango 2016, correct BB size?
Cyrill666
Stockton-on-Tees
Hi Folks,
I have 3 identical Voodoo Bizango bikes from 2016 for my sons and myself. The BB on the one I ride is starting to get a bit noisy and I was looking to replace it. I have all of the necessary tools and have taken the BBs out from all 3 bikes - and they're all worn externally and very little can be seen in terms of markings / codes etc. The only thing I can see for sure is "118" which I guess gives me one of the dimensions, looks like the frame is 73mm wide for the other. They're Octalink.
Can anyone confirm if these are likely to fit (73-118) : https://www.wiggle.co.uk/shimano-es300-octalink-bottom-bracket/
Cheers.
Nigelnightmare
According to the site the Silver ones are available in 73-118 so it should fit as long as the thread size is the same.
Yours look to be BC 1.37x24 I think that's BSA threads.
HTH
robgul
Yep the Silver 118mm is what you want - if you have several of these machines I would "stock up" on spares for future use as they are very, very cheap and Octalink was surpassed some while ago so they will potentially become harder to find.
Rob
Cycleops
Accra, Ghana
Octalink BBs are cr@p as you've just found out. Do yourself a favour and replace them with something better. Even a humble square taper would be preferable.
PpPete
Chandler's Ford
Assuming budget bikes I wouldnt bother changing to square taper (which means replacing the cranks as well as the BB) unless you are looking to do some really serious mileages. Octalink may not be the most successful design, but the Shimano ones linked are quite adequate for a few thousand miles. IMO.
  • Like
Reactions: C R
robgul
Agreed if they are Voodoo bikes I wouldn't spend on upgrades - just buy the octalinks and be prepared to change them more frequently.
Rob
Cyrill666
Cyrill666
Stockton-on-Tees
I can't believe it's taken me 6 months to get around to this! However this evening I replaced the BB on one of the bikes and it was a perfect match - so thanks for all your help guys. As they were so cheap I bought 3, so we should be good for a while!
