Voie verte open source maps Garmin gps
dear all
Is it possible to take the above detailed maps of the cycle routes of France and get them to display on a Garmin edge 1000-does anyone know how to do it? Tried some of the usual open source maps and can't get them to work
Thanks
JB
Milkfloat
An Peanut
Midlands
I have never tried - but have you looked at OSM? http://garmin.openstreetmap.nl/
J
Jerseybean
Member
Hi
I have and I can't get the img file to be recognised on my Garmin 1000-it disappears into the ether
Kind Regards
JB
Dogtrousers
Kilometre nibbler
Take a look at http://velomap.org
I got good OSM based maps of France for my Garmins (60csx and Oregon) from there.
I can't be sure of the voie verte coverage as I've only ridden on the roads in France
Milkfloat
An Peanut
Midlands
Hi
Perhaps I'm not unzipping yet the file does have an img suffix-I can never see the file in maps to enable it-is there a way I can check its unzipped?
When you first got the file from the website, you should have downloaded it as a zip file. You then need to extract the zip file (usually done by just double clicking on the file). This will extract a file that should have the .img extension (although by default your operating system may hide this).
I think at this stage it is better for you to start over and download the file again and follow the instructions posted at http://www.dcrainmaker.com/2013/05/download-garmin-705800810.html very carefully. If you get really stuck, let me know the area you need data for and I can create and host the file for you.
J
Jerseybean
Member
Thanks Milkfloat
but I have done all this previously and when I get to starting up satnav the new maps never appear-tehy are not in activity profiles under Train or Ride under Navigation-obly preinstalled garmin maps which are all enabled-I would like map for Jersey just to practise on
I appreciate all your time
JB
