I’m assuming this crankset will fit Shimano bottom brackets? How do these ones install?
Milzy Guru Wednesday at 21:40 #1 I’m assuming this crankset will fit Shimano bottom brackets? How do these ones install? Attachments IMG_4673.jpeg 129.8 KB · Views: 19 IMG_4672.jpeg 156.9 KB · Views: 19
Jenkins Legendary Member Location Felixstowe Wednesday at 21:45 #2 Hollowtech style BB? If so an 8mm allen key in the non-drive side crank does the tightening.
si_c Guru Location Wirral Thursday at 00:24 #3 Need to check axle size - diameter looks to be 30mm but what's the bearing spacing? - so could be one of a half dozen different BB types.
OP OP Milzy Guru Thursday at 17:46 #4 si_c said: Need to check axle size - diameter looks to be 30mm but what's the bearing spacing? - so could be one of a half dozen different BB types. Click to expand... It’s a 24mm spindle so I’m assuming any Hollowtech BB.
si_c Guru Location Wirral Thursday at 18:17 #5 Milzy said: It’s a 24mm spindle so I’m assuming any Hollowtech BB. Click to expand... I would have thought so.
