Vision freehub problem
philbike
Hi all … first post on here, trying to swap freehubs on a Vision wheel.
Got the hub off, but the axle came with it and I can’t see how to remove it.
Does anyone know?, TIA.
Cheers Philbike…..
Ajax Bay
East Devon
:welcome:12mm hex key, isn't it? (Not entirely clear what meant by "got the hub off" and "it".)
philbike
philbike
Some pics might help 👍
Thanks big john for your response.. I have removed the freehub body from the wheel hub by unscrewing the cap on the non drive side… but the axle remains in the freehub.
I will post a pic when I get home.
Thanks again
philbike
philbike
How to remove the axle from the freehub?
I can’t see a hexagon or circlip ATM.
Cheers phil.
Deleted member 121159
I would have thought that once you take the end cap off, the axle is pressfitted into the bearings inside so you just tap it out. Just a guess.
Usually tap it out, taking one sealed bearing
philbike
philbike
Yeah… me too but its solid ! And I have since heard that some come with the axle fitted… don’t want to force it , not sure about this, 🤔 was hoping someone had experience with vision wheels/ hubs.
