I'm no expert But if you're thinking of putting it on the evilbay I'd say anywhere between £50-£100. Frame looks a bit rough and the front or rear wheel is not original. Suicide levers mean the spec will likely be low.
Stem Shifters, half chromed forks, center pull brakes sort of point toward a Lemans. http://sheldonbrown.com/centurion.html
Probably Tange tubing.
What looks like a Reynolds label may well be a size indicator. I have no information pointing to a Reynolds tubed Centurion, although I think the Equipe(1985) was made with Columbus SL. Almost all others were Tange.
