Twilkes
Getting this back on the road for someone, a few questions:
Can mudguards be mounted on it? There only seem to be mounting holes on the outside of the rear triangle, two on each side, and one on each inside of the forks. There are no central mounting holes at the top but it does have caliper brakes which I've never worked with before, is there a way of bolting mudguards through the brake fittings?
Never worked with a friction shifter front derailleur either, and it's not holding in place on the big ring, I can even push the derailleur towards the frame which moves the shifter. It looks almost brand new so what should I tighten to get it to stay in one place?
http://www.avocetsports.co.uk/vikin...retro-roadie-gents-700c-wheel-road-bike-vp019
