drissa
Regular
I've been hoping to build a bike with an Alfine 8 hub. I got this frame, expecting to be able to cold-set it. From my research, getting the Alfine 8 narrower (with alternative nuts) just seems too difficult. I'm stuck with the OLN measurement of 135mm. The frame is currently around 127mm - so an extra 8mm needed. I'm not sure if the 531*c* frame helps or hinders - it's certainly very light.
I'm hearing very conflicting views on cold-setting, from 'I've done it loads of times, go for it' to 'No way, too dangerous'. The latter is from my local bike store and wheel-builder, so if they won't support it, I'm pretty stuck.
I can try Sheldon's method or the threaded method, but I'd feel happier with more expert input. Am I likely to find another store who will do this? Should I be doing this at all? I don't mind risks during the build, but not afterwards on the road. I'm not into the fixie/SS thing and might have to settle on basic freewheel gears, but don't want to rule the Alfine route out just yet.
Any thoughts/advice would be appreciated.
Thanks, and apologies for what must be rather dull newbie queries/errors
