Hey,
Got a fairly new bike, and for the past few rides I noticed this weird vibration (like slightly more and less resistance feeling) while pedaling. Haven't noticed it before much, as it's being apparent only on higher gears while riding fast on a smooth surfaces (more than sure it's there regardless of surface, just being masked by roughness of terrain). I went to a nearby bike mechanic, he gave it a checkup and told me that mechanically everything is all right. He suggested it might be due to chain being more tense on higher gears, and this is just how my cycle is working (agree it's not most expensive high end bike, but it's not that bad either. At least I hope).
Today I had some more time so I cleaned drivetrain, applied fresh lube and checked it again. Vibration is still there, and after putting my bike upside down to check if anything is visibly wrong while wheels are spinning, I could definitively feel it while spinning pedals with my hand. It's way more intense on higher gears, but it's still there on the middle ones. I don't think it's related to the specific sprockets (that's how the gear wheels are called right?), as the transition in intensity of this feeling is smooth rather than a rigid one.
Do you have any idea what might be causing it? I already cleaned everything and even applied fresh grease to the pedals. Should I just go back to the bike shop with it, or I'm exaggerating and this is just how it is? I would just like it to be a smooth ride, not annoying one.
Appreciate any answers.
my bike info:
Bike is Marin Fairfax 1, alloy frame with rigid fork.
DERAILLEUR, REAR - Shimano Tourney, 7-Speed
DERAILLEUR, FRONT - Shimano TY510
BOTTOM BRACKET - Sealed Cartridge Bearings, Square Taper
CHAIN - KMC Z50
CASSETTE - SunRace 7-Speed, 11-34T
my bike info:
CHAIN - KMC Z50
