Very stupid question.
Hello, I'm going to use my mtb every once in a blue moon to cycle to work along the towpath (I normally commute on my road bike everyday but thought this may be fun). It currently has monstrously chunky 26x2.3 tyres and I want to change them to something akin to a road tyre, the only problem is i don't have a clue what size would fit, could some of you good folk enlighten me please?
Many thanks
Loch side.
26 x 1.5 or perhaps 26 x 1.2 if you can get them. 26 is the wheel size which you can't change, the other dimension is the width, which you can fiddle with within limits.
Brilliant stuff thank you. Would I be able to shoehorn the existing inner tube in or should I get some new ones?
You would 'probably' be able to use the existing ones. It's easier using larger in smaller, as opposed to stretching them wider than they are meant to go. That said, I put the "probably" in because it's hard to know what size inners you have in already. If they were already at the lower end of their recommendation (which I doubt) then it may be a bit of a squish and risk pinch flats.
In short, I'd do it. If it's going to fail, it'll probably fail quickly!
You would 'probably' be able to use the existing ones. It's easier using larger in smaller, as opposed to strong them wider than they are meant to go. That said, I put the "probably" in because it's hard to know what size inners you have in already. If they were already at the lower end of their recommendation (which I doubt) then it may be a bit of a squish and risk pinch flats.
@CopperCyclist - Is that you Andy? This is Chris.
I used to race MTB on 1.5" tyres, with no issues, so towpaths/bridleways ought not to be a problem
Look at the rim of the wheel (or on the present tyre) for a number that is in the format XX-YYY
XX is the width of the tyre and YYY is the diameter of the wheel
The width can be varied within reason, but the diameter is fixed.
25-559 would be a narrow 1 inch width tyre on a typical mountain bike, and 50-559 a wide 2 inch tyre and would fit the same wheel
It is more accurate that the "26x1.5" format as these are unreliable.
This page from the CTC explains
Thank you for all the replies, got the 26x1.5 city jets. Rode the towpath and though it was a lot harder work than the road bike it made a great change.
Steady
Derby
I was in a similar position, and I went for these http://www.chainreactioncycles.com/michelin-city-bike-tyre/rp-prod69985 a few years ago, I think I went for 1.4" version (but memory fails me on that), getting rid of the knobbly bits seems more important than width to be honest.
That said, I fitted the above fine with existing standard MTB/cheap inner tubes.
Just be prepared for everyone to tell you that your tyres are knackered, everybody who saw my bike without knobblies told me I should get new tyres. :wacko:
