Veloce shifters
Martin p
Sheffield
Hi there Lads & lasses , after a bit of advice if anyone can help.
After damaging one of my shifters in an accident I was thinking of replacing my Shimano 2300 levers with Campag Veloce . I've looked on the internet including cycle chat & it seems it can be done . My dilemma is that on Ribble's site there is a double that is triple compatible & a triple specific version. Will both work or am I better just going for the triple . Cheers :-)
RecordAceFromNew
Swinging Member
West London
No issue with the rear, and either should be fine with a double chainset (by letting the L limit screw set the inner ring position and leaving the cable a little slack there). But it is going to be more difficult with a triple because Campag front cable pull is greater than Shimano's for road fd, and these lower groups don't have as much trim control as the Ultrashift in higher groups.
Martin p
Martin p
Sheffield
Cheers Recordace , my bikes group set is pretty much all Shimano 2300 & is an 8 speed triple . I was hoping this would work
Martin p
Martin p
Sheffield
Sorry , must have caught "post reply " by mistake . As I was saying I was hoping this would work as I upgraded the chain set , cassette & chain to better versions of the same components the summer gone & dont really want to buy 2300 levers again .
