taximan
senex crepitu iuvenis cordi esse
- Whitby North Yorkshire.
This may sound elementary to some, but can I use schrader & Presta valves in the same rim. Cheers.
This seems an unlikely scenario?
There would only be one valve per rim, do you mean different valves on each wheel? If so, that should be OK, just as long as you have a pump and adaptor to fit both valve types.
http://sheldonbrown.com/brandt/presta-schrader.html[/quote]
Hmmm, You're right, It would seem a bit strange with two valves sticking out of one rim, perhaps I could have phrased my question more clearly. The reason I asked is my bike was fitted origionaly with Schrader valves but I had to replace both tubes and used a couple (fitted with presta valves) which I already had and have been using them for a couple of weeks now. Hovr's reply more or less confirms what I thinking.
Adrian, Is the plastic Adapter you mention readily available, I did ask in (dare I say it) Halfords the other day and got nothing but blank looks.
Thanks for your replies folks.
http://www.spacycles.co.uk/products.php?plid=m2b0s123p1765
Though I just cut a piece of old inner tube, make a hole in it and push the presta valve through the hole. The resulting double thickness at the bottom of the valve has prevented any tube damage and "balloon" problems.
Thanks for the tip & link
