V brakes on a Tricross
ror3h
Are they definitely mini-v brakes and not regular ones? I fitted some tektro mini-v's to my tricross a few years ago and it worked great straight up. Are the pads straight and aligned with the brake track?
Garethgas
It might be the levers? Measure from the pivot to the centre of the cable end. It should be from 35 to 40mm approx.
Less than that and they will be touching the bars.
Nigeyy
I haven't had experience with mini vs but.... a long shot.... are your cables in need of replacement (as in new housing)? Also check your cabling routes (again a long shot but sometimes optimizing your cable runs can make a difference).
If you aren't married to STI or Ergo, you could also try different levers -I have road levers with only slightly different pull lengths (talking millimetres here) but give a very different feel. FWIW I find older Shimano STIs have a shorter pull compared to, say, Cane Creek road levers (not talking about long pull v-brake compatible road bike levers either but canti/dual pivot specific levers). I really wish brake lever manufacturers would publish exact cable pull lengths, but that's another story.
Well, good luck!
edit: found this, may make interesting reading http://www.gravelbike.com/?p=3298
Globalti
Can't comment on the cable pull issue but from the top photo I can tell you that you've got the brake blocks badly mis-aligned. The block on the left looks to be canted downwards and the block on the right, a little upwards. This would mean they aren't contacting the braking surface square on, which would cause a spongy feeling and lack of power. The easiest way to align them to the rims is to loosen that bolt and stack of washers and dished spacers, then hold the brake on and wiggle the block until it finds its position sitting fair and square on the rim then begin gently to tighten the holding bolt until everything is tight. Your problem here will be that the torque that you put on the bolt will tend to pull the brake block out of alignment so pressure from the brake lever and holding the block with your fingers to prevent it from rotating will be needed. Another hand to hold the brake on might help, or I suppose you could use an elastic bungee wrapped round and round the lever and grip. Get the blocks so that there's a millimetre or so of clear braking surface above and below them because they are tapered and will need more width as they wear.
This might take several attempts to get right but in the end you should find that the brake blocks are both at the same height in those slots and look symmetrical when viewed from behind.
Next, adjust the little spring tension screws at the bottoms of the brake arms to get both brake arms standing up parallel. Tightening the screw increases spring tension.
Then adjust the cable length to get the blocks the right distance away from the rim. When you grab the brake you should hear the blocks contacting the rims with a little "clack". If the above doesn't improve things dramatically you have a cable-pull ratio problem and I can't advise you.
If the bakes squeal when applied, repeat the alignment exercise but toe the blocks in by trapping a twice-folded cereal box lid flap between the rim and the trailing edge (rear) of the brake block then tightening everything up.
Globalti
You just need to get those brake pads sitting flat against the braking surfaces. The rest will follow.
