So I'm looking at upgrading the brakes on my Dawes to dual pivot ones, but of course they have recessed fittings (my Dawes is a steel frame designed for non-recessed brake fittings).
One way of getting around this that I've heard is to use the front caliper brake on the back, using a regular nut and washers to fasten it on, and then use the rear caliper on the front (which has been drilled out to 8mm) with a long recessed nut.
Does anyone have any experience with this? How long will the new recessed nut for the rear brake on the front have to be? I've found 10mm and 18mm versions at Wiggle, and a 30mm version at SJS, but I want to ensure I'm buying the right thing.
Thanks in advance.
Thanks in advance.
