Cope
- Wickham, Hampshire
Looking at gear ratios, how does one make the best use of a set like this:
Assuming one averages at around 70 inches, as one does on fixed, and might drop to 60 or so for smallish hills, and move up to 80+ for longer flat or downhill sections, how does one get the most efficient change?
It'd be annoying to have to change both up -and- down, to go from middle to outer ring, to move from 80.3 to 83.6... so maybe one starts on the outer ring on 70.4? But then down to 63.7 might be too much?
All I do know, from older cycling days, is that one should avoid too much chain stretch, so smallest on the rear with largest on the front (ie 63.7) would be avoided.
102.9 80.3 61.8
95.6 74.5 57.3
89.2 69.6 53.5
83.6 65.2 50.2
78.7 61.4 47.2
70.4 54.9 42.3
63.7 49.7 38.2
