Using copper grease in Dia-Compe roller brakes
gazza19
hi can i use copper grease in a roller brake it squeels every time i apply the brake its an pro bike e voyager electric bike
mjr
What's the brake? A Shimano rollerbrake? That should have a special Nexus brake grease according to http://www.sheldonbrown.com/rollerbrakes.html - you might be able to replace it with some other greases but I'd be surprised if copper grease was one of them.
gazza19
gazza19
here are some pics
Tim Hall
Crawley
Shimano do a special grease for use in their roller brakes. Going from the colour it's not copper grease though.
I can't see from your picture what make your roller brake is though.
gazza19
gazza19
mjr
It says DIA-COMPE on it. Here's a set of service docs for a similar brake on another brand http://volto.co.nz/docs/Diacompe_Service.pdf which suggests CV Joint Grease will work. That Chinese sticker probably says "Insert Grease" with the arrow pointing at the cap at the top.
I still wouldn't put regular copper grease anywhere near it. Too thick and wrong stuff in it. I think it's more of an antiseize than a lubricant.
gazza19
gazza19
This third party maintenance document suggests CV joint grease.
thanks for your help pal
msd123
I found this thread useful to solve the exact same issue.
Since I live on the top of a 1:7 1/2 mile long hill I use the brakes a lot so sooner or later I'll be needing to replace the whole (roller brake) unit. I had a look to see where I could buy one and this raised a few questions
1) a Dia Compe MLB-50 is available (from Japan - postage to UK doubles the cost :angry:) but is that the correct unit for the E-Voyager Pro-Rider ?
2) does the replacement have to be Dia Compe or is there a generic alternative (e.g there are some "servo 90" units on Ebay that look similar and are much cheaper) ?
rogerzilla
Moly grease (the black stuff) is good for this sort of job. It's what you use in cheap coaster brakes.
