Upvc window handle
stephec
Bolton
We have a window with a broken handle, replacing it looks to be as simple as -
Unscrew old bits
Slot new part into locking mechanism
Screw new handle on tight
Is it really that simple or have I missed something?
screenman
Unscrew old bits
Yes it is very easy, I did my front door handle in minutes, I bought mine from Tool Station.
alicat
Staffs
Think it could be prudent to dismantle and measure the shaft length and buy one of that length or be prepared to cut it. Maybe most modern windows have the same shaft length.
lazybloke
Priest of the cult of Chris Rea
Leafy Surrey
I found it very easy to replace a handle on a relatively recent window (about 20 years old).
A different story on an older door; that whole thing is being replaced soon.
stephec
stephec
Bolton
Cheers everyone, job jobbied.
Only trouble is the lock mechanism'quite loose so it looks like a new window's needed.
When you say the mechanism is loose, you might just need to undo the Phillips screws and replace the mechanical bits as opposed to a new window.
newts
Isca Dumnoniorum
Might be just the plate on the frame need adjusting & tightening. The locking mechanism (espagnolette rod) is pretty cheap to replace if faulty.
