Upgrading to hydraulic brakes-di2
justinmg
I have slowly and expensively upgrading my road bike over the last few years. It has di2 mechanical brakes going to TRP Hyrd hybrid disc callipers. These have 35mm mounting centres with a 72 mm mounting plate on the front fork.
If I was to move to Ultegra 8070, would the callipers be a simple swap. Shimano don’t show the mounting plate dimensions on the exploded view in tech docs…..
Thanks
Cycleops
Accra, Ghana
As long as the mounting system is the same and it will handle your disc diameter you should be good to go.
