longers said:Thanks Monty Dog, I live and learn eh?
I only replaced it because it was broke though.
longers said:I did this last month, no problem at all. I went from Sora 8spd to Tiagra 9spd.
The shifting is noticeably smoother.
Monty Dog said:The improved smoothness is probably due to the new chain and nothing to do with the mech - it's the shifter that dictates the quality of the 'shift' as well as having a 'clean' cable run. Upgrading gear mechs is probably the most pointless upgrade, better off spending the money on shifters, brakes, contact points but not the gear mechs. I only ever replace gear mechs when they break.
shooter560 said:I disagree, I've just upgraded from 105 to Ulterga SL and then to Sram Force rear mechs, each upgrade 2 weeks apart did not include any other drive train changes and the smoothness in gear change was noticeable especially when changing under load. I think its all to do with the strength, smooth pivots, lack of flex, better bearings etc that makes the difference I've felt.
bianco said:Same here, thats why I wanted to upgrade.
About the front mech though, do they differ in quality?
