migrantwing
I posted here recently about chainrub problems I was having. No matter how I set up my front DR, there was chainrub when in small front/large rear and large front/small rear. NOTHING I did to tweak the FD position would prevent the rubbing. After trying everything, even widening the FD cage slightly, I still got chainrub. It could only be one other thing...a less than perfect chainring.
I know that the bike hasn't fallen over or been in any kind of accident that would bend the chainring, so it must have been bent whilst in transit at some point or other. I have succeeded in sorting this problem out with square taper BB's with this method (video below) but is it possible with a Hollowtech II BB? The setup on HTII has it so the little 'pin' on the large chainring sits directly behind the crankarm and the little arrow on the smaller chainring lines up with the crankarm too. Would the front shift be as smooth if I rotated the chainrings to a different position to try and alleviate the run-out in the chainring , or does it require that the pin and arrow are ALWAYS set up to be behind the crankarm? It is not that there are a few bent teeth on the chainring, it's more like the chainring is not perfectly flat when placed on a flat surface making it run out for the distance of about a third of the chainrings circumference, hence the rub. It's more warped than bent per se.
Click on link underneath the video NOT the video itself, it will jump a few minutes to where the interesting stuff is
View: http://www.youtube.com/watch?v=-mU6Dyt4SQg&t=2m2s
