Unknown frameset.
PHL67
Frinton on Sea
496230
496231
496232
496233
496234
496235
496236
496237
496238
496239
Not sure what it is but it is nice.
Any of the members any idea on its make and age.
I am pretty sure it is very old.
Number on forks and bb 495. 1825.
Smaller numbers 01004.
Badge holes around the side of headstock.
Any help greatly received.
biggs682
Northamptonshire
Some nice fork crown lugs and greese ports on head tube and bottom bracket
carpenter
suffolk
^^^^^ not sure about that - surely it depends on when cast dropouts first appeared and how old the frame in question is?
I have an F C Parkes - I think 1950's and a Carpenter (1957 from serial number), both quite aspirational bikes at the time which have pressed dropouts.
Time and place for everything :okay:
Stompier
'Aspirational' and 'quality' are not necessarily the same thing though. And unless the frame was made around 3000BC, it has always been possible to cast dropouts ;)
Raynal Cycles Birmingham have a head badge with hole on either side .
carpenter
suffolk
Absolutely right, "delightful" is a subjective term,
You are also correct that "aspirational' does not indicate that an item is a "quality' product.
However just the fact that these frames are still in use after sixty years suggests that they were/are a quality product.
Unfortunately, you don't seem to have picked up on my point that dismissing a frame as "nothing special" because it has pressed dropouts is ignoring the possibility that the frame was made before cast dropouts were used in bike frames.
Does anyone here know when cast dropouts became available and de rigueur for "special frames" ?
And explain what a "special" frame is? 😂
Dunelt also had a head badge with holes on the sides . Raynal bought the rights to Dunelt in 1937 and produced them at their factory in Birmingham . Raleigh bought Raynal in the early 60's to acquire the Dunelt brand .
carpenter
suffolk
Now your just getting even more silly. I think that the Chinese first cast metals about 2500 years ago (not 5000 years ago :rolleyes:)
As for making bike parts as soon as the technology was available well really; Aluminium was first commercially produced in the mid 19th century, it wasn't until the 1960's that a bike frame was made with it.
Serious question (again) when were cast dropouts first used on bikes, or do you just not know?
"Special" bike? or would you rather just forget that ?
Just to help here's a special bike for you:
496363
