Ceiran
- Staffordshire
Hi, I had this bike second hand and I'm trying to get it back to working order but I'm also a novice, the rear brakes are awful and I noticed the pad isn't contacting the rotor at the bottom, it was more uneven than this initially but I sanded the pad down a bit and rubbed it down with isopropyl, I figured actually there's probably an underlying issue as to why the pad wore uneven in the first place which I should look into trying to rectify before replacing the pads. If anyone can give me a few pointers in terms of what to look at/correct before replacing the pads I'd be really grateful. Thanks in advance for any help.
I believe the brakes are Zoom mechanical brakes with a single piston caliper. (Please correct me if I'm wrong
