MacB
- Farnborough, Hampshire
I got an Alfine crankset this morning and it's the two piece with external bearing bottom bracket rather than the one for a cartridge BB I intended...my own fault. But this has got me looking at stuff and thinking, could people help verify, or correct, my understanding of some things...warning this will be lengthy:-
Cartridge BB's - inboard bearings and you select to match cranks and BB shell, assuming no chainstay interference, can you select any axle length to get a preferred chainline?
Outboard Bearing BB's - like the one I have in error, again I get that you match BB to cranks but how can you mess about with chainlines? Can you use spacers or are you limited by the axle length supplied? I'm thinking for single chainring use here. What's the longevity of these sorts of BB's like compared to cartridge ones and are the bearings more vulnerable to leakage/ingress being on the outside?
BB30, BB91 etc - these are outward bearing ones again but need special BB shells?
Eccentric BB's for EBB shells - I understand that these require a special oversized BB shell and that the EBB is an insert to this that allows a normal cartridge, or OBB, bottom bracket to be inserted off centre. The EBB can then be rotated within the shell to alter the length of the chainstay and tension the chain, the alterations vary from 1/4" to 1/2"? The different options are:-
Split Shell EBB - this is where the shell has a lengthways split which can be tightened by two bolts thus holding an EBB insert in place? not sure of any examples of EBB inserts for this use but assume you can use any ones that would normally work via set screw? - critics claim the split allows for too much water/muck ingress and it is prone to creaking and slippage?
Set Screw EBB - shell is complete but has two holes underneath for set screws to be inserted. The EBB insert is fitted to shell and then the set screws are used to stop rotation, this is how the Phil Wood ones work? - again tales of creaking, slippage and the set screws creating indentations that limit the positions you can use?
Expanding Wedge EBB - again shell complete but a bolt is tighted from side of EBB insert to expand the insert and hold it in place? - gets worst write ups for creaking and slippage but easiest to maintain? Bushnell is well thought of and there's a Carver model that claims to have sorted the slippage/creaking issue by having a nylon sleeve that provides better surface to surface grip.
Outboard gripping - Niner have a new insert that bolts through to the other side and the cups grip round the outside ends of the BB shell. Claims to solve creaking and slippage problems but I've read some horror story reviews that indicate poor performance unless everything is absolutely perfect.
Eccentric BB's for normal shells - these only work with 2 piece cranks with 24mm axles and the EBB itself contains the bearings and replaces the OBB? These give a 1/4" of throw and adjustment is to each side of the BB and so misalignment is possible thus overstressing bearings? I'm aware of 3 models:-
Excentriker from Trickstuff - setup is fiddly but ongoing adjustments are the easiest, one set screw each side, needs special tool for installation which you buy on top of the £150 EBB.
Forward Components - similar setup to the Excentriker but adjustments are via 12 set screws, 6 on each side, special tool again but at least they throw it in with the EBB, about £120
Philcentric from Phil Wood - they have the 1/4" EBB insert for EBB shells introduced to minimise changes to ride position via EBB and this is their take on the EBB for normal shells. Workings are similar but the initial setup requires special tools and they are only supplied to bike shops at present. The maintenance adjustments are by the user after that but do require removal of the crankset to achieve. Unlike the other two this isn't infinitely adjustable there are set points at 15 degree intervals, About £150 again.
I have seen claims around slippage, but not creaking, for all 3 of these but generally associated with heavy duty SS use. I was wondering if these would be an ideal solution for hub gears in a normal vertical dropout frame? One of the criticisms of them is that they don't provide enough throw to be able to change gears around for SS or fixed riding. but if you're only wanting one to take up slack due to chain wear, and won't be brutalising it via SS/fixed use, then wouldn't it be more than enough? Obviously you'd want to start with as close to a magic gear combo as possible but a total of about 7mm horizontal should be enough shouldn't it? I've seen writeups about SS/fixed conversion where they've almost got a magic gear and have just taken a file to the vertical dropouts to give them the required 1-2mm to make it work. This would be a positive luxury of ajustment in comparison to that, I'd also be employing a halflink if need be. So, work out chainring/cog combo, install with EBB and just tighten as chain wears. When you run out of adjustment, and the chain is too slack, then time for new chain. As for the BB itself, I understand the cups last for ever(or at least a darn long time) and you just keep replacing the cartridge bearings as they wear out?
Would be interested in sanity check info re the above and any real world experience of the Excentriker, FC EBB or Philcentric...as I've got the 2 piece cranks the £150 outlay is looking a bit less painful.
Merry Xmas
Merry Xmas
