U
User6179
Apparently Shimano Ultegra 6700 and maybe 105 5700 shifters are jamming and the reason is this little retaining nut which helps hold the gear mechanism in place unloosens itself through normal use.
Just took this nut from my working shifter and put it on my jammed shifter and it works perfectly now but I now need to locate another nut for the other shifter which is proving quite hard to locate .
Anyway thought I would just post this as someone maybe able to tell me where I can get this part or even find out what the part code is as Shimano docs is unhelpful plus for anyone who has a jammed shifter lying they can just pull the brake lever fully and look down through the gap into the shifter and see if the nut is missing.
