Gooch
This is a weird one. I've only ridden my new bike twice but each time I build up speed to go down a steep hill my front brake comes on of its own accord. I'll look down at the calliper and see the brake block rubbing on the rim and the whole bike vibrates. I then brake to a stop to see what has happened. As I begin to a slow almost to a stop, it releases.
Now I could understand it if I put on the brakes and they then locked to the rim, but I'm not actually touching the brakes. They are coming on on their own. It can be a bit embarrasing when you're ridiing with other people because they just think you've bottled it on the descent. I gonna wip the front wheel off later and put plenty of lube around the calliper to see if this helps. The calliper itself is not loose on the forks so I can't understand it. I've never come across anything like this before. Anyone else? B)
