So effectively I can use them, but are all disc hydraulic? There are cable disc and hydraulic disc?They can if the new brakes are cable actuated disc brakes....they cannot if your new system is going to be hydralic which im guessing it would be as 8070 is hydralic so no,you cannot use them.
I really don't know tby. All I fundamentally want to know is this. I have 8050 di2 ultegra. I want to go to a disc brake bike, can I take the di2 shifters over with me (without buying another pair) that's all Im fundamentally asking, sorry to be all over the shop, are 8050 and 8070 compatible, I found a website that had 8050 di2 disc ?Are you asking whether cable levers are compatible with hydraulic calipers?
Ask yourself: Does my 8050 shifters, the ones I have here in my hand, work with brake cables, or do they have hydraulic hoses?I really don't know tby. All I fundamentally want to know is this. I have 8050 di2 ultegra. I want to go to a disc brake bike, can I take the di2 shifters over with me (without buying another pair) that's all Im fundamentally asking, sorry to be all over the shop, are 8050 and 8070 compatible, I found a website that had 8050 di2 disc ?
Cheers, that's the clearest answer I've had. I will need new di2 shifters as the ones I have are brake use only.Ask yourself: Does my 8050 shifters, the ones I have here in my hand, work with brake cables, or do they have hydraulic hoses?
Then the answer to your question should be obvious. If you are still unclear, someone will spell it out for you.
You mean "cable use only"? Don't confuse yourself further. You need new shifters.Cheers, that's the clearest answer I've had. I will need new di2 shifters as the ones I have are brake use only.
You only have to change the shifters. If your front and rear mechs are already Di2, they are fine as is.Thanks, I'm not the most technical of people when understanding groupsets/gears/set ups.
Now I know I'll need a completely different groupset. I have 8050 rim brake so I need to change everything, right? Shifters/frnt-rear mechs?
Cheers....that is great news.You only have to change the shifters. If your front and rear mechs are already Di2, they are fine as is.
Ignoring the Di2 functionality the only real difference is 8050 operates cable brakes and 8070 operates hydraulic (disk) brakes.Cheers....that is great news.
I don't really know the difference if I'm honest
