Ultegra 6700 gear cables - how the .... do you fit them?
DCLane
I've been trying to fit the gear cables onto the Ultegra 6700 shifters for my Ridgeback Platinum update. The cables are being attached to Dura-Ace 7800 front and rear mechs.
However, despite following the Shimano video they're just not working. I'll get a couple of clicks and then nothing.
So, any suggestions please?
I've put the cable through the hole and they're coming out the correct end. Do I need to move a lever or something to get them to stay?
simon.r
Person
Nottingham
I like to think I'm a competent home mechanic. I can strip and rebuild a bike, true wheels, remove stubborn bottom brackets, replace headsets etc etc.
When I needed a cable replaced in my 6700 shifter I spent about 3 hours trying...then gave in and paid the nice man at my local bike workshop a tenner:rolleyes:
Cubist
Still wavin'
Ovver 'thill
Just a thought, and a similar thing happened to me. As you peel back the hoods to fit the cable it is possible to dislodge a small lever actuator which moves the indexer. Have a look to make sure this isn't just sticking out. It simply needs pushing back in again.
sounds as if its not indexed properly...
undo from the cable from the Mech , set the shiffter into its lowest gear/position then tighten the bolt on the mech
failing this the gear cable has been inserted incorrectly through the shiffters
DCLane
DCLane
Thanks all - I've spent the past hour with the video, paper instructions and others. The cables are seated properly, the actuator in, it's fitted to the F&R derailleurs where I would with my 105 shifters. Still I get a couple of clicks and then it appears to move out of position and not click any more.
In the end I've given up; it'll be off to the LBS on Tuesday before I get cross with it.
